TheGuru47
May 26, 2025Aspirant
NETGEAR WAX610 Dual-Band WiFi 6 Access Point
Hi. I want to create a local network that allows my devices to communicate directly with each other without having an internet connection. This way, I can use a master/slave app during band rehearsa...
May 29, 2025Guru - Experienced User
TheGuru47 wrote:I’m under the impression that setting up the wireless access point (and devices that will connect) using static ip addresses will allow me to accomplish what I want … to use the wireless access point as a stand-alone device that will allow on-stage iPads to communicate with one another. Does that make sense if the only thing throwing a router into the mix would do is assign ip addresses?
The idea with the router was to add in a DHCP server to the mix.
Static addresses would work. schumaku is saying there other other options - for instance Bonjour for Apple devices (more generally known as zeroconf). I don't doubt that - I suggested a router because your initial post said you were a networking novice. So I was aiming towards a really easy solution (and was assuming you could still exchange the WAP for a router with similar wifi performance).
TheGuru47
May 29, 2025Aspirant
Got it. I’m a novice when it comes to wireless access points. I’ve never configured one before, but I think I have it all figured out. Most appreciative for everyone who assisted with helping me understand what was required. Now I know more than I did before (and that is never a bad thing).
