stewcoarchives
Oct 05, 2023Aspirant
New WAX610 - Internet connectivity for laptops but not smartphones
I just installed a WAX610, hardwired to a nearby, new Netgear GS308E switch in a new office. The switch connects to the building's router, somewhere in the building. The AP has Internet connectivit...
- Aug 06, 2024
Final Update 6 Aug 2024:
The experiment to change my WAX610 from Bridge mode to NAT mode was very brief. Although smartphones finally gained Internet connectivity, the bandwidth was excruciatingly slow so as to be unusable.
Down here in the basement where all of this has been happening, the adjacent office requested the IT folks upstairs to install WiFi for them (probably since mine was unusable to smartphones). Their new WiFi antenna (I've never seen it) provides quick, reliable connectivity both to our PCs that have never had a problem, as well as our smartphones which always had a problem with the WAX610.
I have decommissioned the WAX610.
stewcoarchives
May 21, 2024Aspirant
Today's experiment was to change the WAX610 AP from Bridge mode to NAT mode, so that the WAX610 would issue IP addresses instead of the upstream router.
After changing to NAT mode, my Android smartphone connected to the SSID on the WAX610, received a private IP from the WAX610, and had Internet connectivity right away. This is the best result thus far - open connectivity for smartphones without that annoying "Internet not connected" error.
stewcoarchives
Aug 06, 2024Aspirant
