DougMH
May 03, 2023Tutor
NightHawk M1
I have an NightHawk M1 (SN: 6A8112NV52139). According to the AT&T coverage map, I'm close to a 5G coverage area (red circle). The M1 see what is in picture to. I know an M1 is supposed to be only ...
May 03, 2023Guru - Experienced User
There's 5g cellular (5th generation) and 5g wireless (5ghz).
They're different. what you're seeing/connecting to is the 5ghz wireless.
The M1 isn't 5g cellular.
Would you see better speeds with a M6? Maybe? those maps tend to be a little generous on how much they actually cover.
