DougMH
May 03, 2023Tutor
NightHawk M1
I have an NightHawk M1 (SN: 6A8112NV52139). According to the AT&T coverage map, I'm close to a 5G coverage area (red circle). The M1 see what is in picture to. I know an M1 is supposed to be only ...
DougMH
May 03, 2023Tutor
Got it thanks. I only use the M1 for my wireless so what you say explains it.
I guess now the question is if I upgraded to a M6, would it make a particle of difference in that 5G wireless.
Not sure I want to spend $600 to find out at this point.
Again, thanks for the quick response.
