bmomjian
Jan 22, 2019Guide
Occasional wireless traffic hang
I am seeing occasional hangs on my WAP network. Ssh to the WAP normally shows 95% idle and 0% isrq for top:
Tue Jan 22 23:00:01 UTC 2019
23:00:01 up 1 day, 23:54, load average: 3.01, 3.01, 3.04
Me...
- Aug 19, 2019
I am happy to report that firmware 3.9.1.0 has been released, and I think it fixes the problem reported in this thread. The release notes document is dated August 13, 2019, mention these two fixes:
1. Addressed intermittent, rarely encountered access point hang issues.
2. Fixed various stability and connectivity issues.I think this closes the issue. I will keep my monitoring in place for another year to verify the fix. Thanks to all who helped.
bmomjian
Jan 24, 2019Guide
OK, I will grab the logs once it happens again, though I have sent 50% sirq logs to you before and you said it looked fine.
bmomjian
Jan 25, 2019Guide
Last time I got the 50% sirq at exactly 48 hours of uptime. I have passed 48 hours since the recent reboot and the sirq% is still zero. I will report back and grab the logs as soon as my logging informs me that sirq has increased.
- schumakuJan 28, 2019Guru - Experienced User
Mem: 77772K used, 177356K free, 0K shrd, 0K buff, 20872K cached CPU: 0% usr 0% sys 0% nic 49% idle 0% io 0% irq 50% sirq Load average: 4.00 4.01 4.05 6/71 7314 PID PPID USER STAT VSZ %MEM CPU %CPU COMMAND 9 2 root RW 0 0% 1 50% [ksoftirqd/1] 1111 1 root S 11656 5% 0 0% /usr/sbin/dman 1518 1111 root S 13880 5% 0 0% /usr/sbin/snmpd -f -c /tmp/snmpd.conf udp:161,udp6:161 -LO 0 1626 1111 root R 7196 3% 0 0% /usr/sbin/cportald 1104 1 root R 4984 2% 0 0% /usr/sbin/mapd 1597 1111 root S 4496 2% 0 0% /usr/bin/mini_httpd-ssl -S -E /etc/mini_httpd.pem -D -p1 80 -p2 443 -t 5 -s 1 -u root -c ./*.cgi|*.cgi|cgi-bin/ 1593 1111 root S 4440 2% 0 0% /usr/bin/mini_httpd-ssl -D -p1 80 -p2 443 -t 5 -s 1 -u root -c ./*.cgi|*.cgi|cgi-bin/* -n 20 -Y ALL:!aNULL:!eNU 1541 1 root R 4312 2% 0 0% /usr/sbin/dhcpdump brtrunk 1415 1111 root S 4228 2% 0 0% /usr/sbin/mapqosd 986 1 root S 3736 1% 0 0% /usr/sbin/tspec 1542 1111 root S 2244 1% 0 0% /usr/sbin/hostapd /tmp/hostapd.conf.wlan0 /tmp/hostapd.conf.wlan1 1073 1 root S 1696 1% 0 0% /usr/sbin/asengd 1416 1111 root S 1540 1% 0 0% /usr/sbin/lldpd 8774 8770 root S 1488 1% 0 0% -splash 1066 1 root S 1424 1% 0 0% insmod /lib/modules/2.6.36.4/extra/wlext_ae.ko 1427 1111 root S 1416 1% 0 0% /sbin/udhcpc -l /tmp/udhcpc.lease.brtrunk --foreground -i brtrunk -H WAC730-1 -s /usr/share/udhcpc/dhcp_client. 1 0 root S 1412 1% 0 0% init 15908 8774 root R 1412 1% 0 0% top 1133 1111 root S 1412 1% 0 0% /sbin/getty -L 115200 ttyS0 940 1 root S 1400 1% 0 0% insmod /lib/modules/2.6.36.4/extra/wlext_wds.koLucky me had to move the WAC730 away from the Insight switch to an elderly GS510TP in attempting to check if the latent IGMP Multicast issues (still can't get any Apple Drive Bonjour announcements e.g. for Time Machine) are caused by the new Insight switch firmware 1.0.4.16 or the WAC505/510 on 5.0.10.2 ... sorry for the slightly off topic, but now the 50% sirq is obviously gone again for a while.
