danielson96's avatar
danielson96
Orbi pro srs60 wont let me login to change settings
I would like to ensure  the IP that is been provided by switch to Orbi pro srs60 is the correct one. How do I login to the Orbi pro srs60?
I have already tried to use the generic: username for username and password for password. admin, admin, and other generic logins but it wont let me login.
I have already reset to factory settings so I can use the above login but it will not let me login.
My connection to the Orbi is via laptop and a network cable.
Thank you in advance!
  • plemans's avatar
    Does it connect through insight?
    Did you try logging in through that router?
    Maybe insight is updating it even after the factory reset.
    • danielson96's avatar
      danielson96
      Do you mean the Insight phone app? No i have not tried that yet but I will. Will that give me access to ip settings from switch?
ProSupport for Business
