CDE2
Aug 18, 2022Aspirant
POE powered access point - with a POE port for CCTV camera ?
Hi, does anyone know of a Netgear Wireless Access Point that is powered by POE and provides a POE RJ45 port to power a poe enabled CCTV camera? Regards
michaelkenward
Aug 18, 2022Guru - Experienced User
Did you check the product pages?
Wireless Access Points | NETGEAR
17 at last count.
Here's one:
Cloud Managed WiFi 6 PoE Wireless Access Point | NETGEAR
CDE2
Thanks, I have looked at that one - amongst many others - but although it allows you to power it up with POE it does not give you a fresh port to connect to another device that requires POE. It only has one RJ45 on the back and that is where it would get POE input to power it up. Regards.
- michaelkenwardAug 18, 2022Guru - Experienced User
There are models with more ports, but powering the camera might be beyond them.
