PaddyVu's avatar
PaddyVu
Tutor
Apr 06, 2019
Port forwarding wont work
I cant port forwarding to 8193,it doesnt work at all,i read some web that said services must run on that port but i dont know how to do that. I'm try to play MHW on remotr using mobile data and PC using router wifi,2 diffirent network but i cant :( if someone can help me teamview it would be great !
  • Hi @PaddyVu,
    Since this community is dedicated for NETGEAR Business Wireless Access Points, it would be best that you either contact the G-97RG3 Technical Support or if ever your Internet Service Provider installed the G-97RG3 router for you, then you can contact them for technical assistance.
    Let me inform you that there is a YouTube video about Port Forwarding on the G-97RG3 router.  However, it is on Vietnamese language (if ever I'm not mistaken).  You may want to check it on YouTube.
    DaneA
    NETGEAR Community Team
  • schumaku's avatar
    schumaku
    Router model, firmware version, ... what ISP, what Internet CPE/modem/router in front (probably duouble NAT)?
    Your ISP does assign public routeable IPv4 addresses to your Internet connection to _that_ router?
    Afraid, in-line image moderation does take much to long here, so we won't see the images before next week or so.
    • PaddyVu's avatar
      PaddyVu
      Tutor
      I dont know anything about my network,how can i check it? Can you teamview and help me? :(
    • PaddyVu's avatar
      PaddyVu
      Tutor
      I think my router model is
      Model Name G-97RG3
      Software Version R4.2.43.078g
      Hardware Version C30-401
      My isp : FPTDYNAMICIP also known as 'FPT Telecom Company' and 'The Corporation for Financing & Promoting Technology' ( i check this from whoismyisp org)
      "what Internet CPE/modem/router in front (probably duouble NAT)? " what is this? how can i check it?
      "Your ISP does assign public routeable IPv4 addresses to your Internet connection to _that_ router?" i dont know,how can i check it?
      • DaneA's avatar
        DaneA
        NETGEAR Employee Retired
        Hi @PaddyVu,
        DaneA
ProSupport for Business
