Southst
May 29, 2023Aspirant
Power requirements for WAX214v2
What are the minimum power requirements when using a Poe+ injector with the wax214v2 access point? Approximately 50’ run from the Poe injector to the wap. Thanks.
microchip8
May 29, 2023Master
Can't find or Google for documentation???
Go to NETGEAR's site, go to Support, enter your model number, get PDF, read!
- SouthstMay 29, 2023Aspirant
That would have been an extremely helpful response if the documentation for that wap, which I had previously read, actually specified minimum power requirements. Unfortunately, as far as I can tell, it doesn’t, so it is not.
