Southst
May 29, 2023Aspirant
Power requirements for WAX214v2
What are the minimum power requirements when using a Poe+ injector with the wax214v2 access point? Approximately 50’ run from the Poe injector to the wap. Thanks.
schumaku
May 29, 2023Guru - Experienced User
It's printed about 100 times (wild guess) in the WAX214v2 User Manual
PoE+ (802.3at) switch is required, however a PoE (803.2.af) switch might be sufficient if the the AP’s 2.4 GHz radio works with reduced transmit power. Certainly not something I'd see as a normal suggested operation status,
The minimums are set by the IEEE standardization - this depends on the possible length of the installation. Again not something you should consider as an installation standard, unless you are to cheap to invest in industry standard PoE+ switches.
Strictly stay with the IEEE Standards, like 802.3at or bust. Can't be easier.
Can't wait for a new post where somebody comes and lists cable quality and length, some voltage and amps details, in-span and out-span blah, and so on. Far to many power injectors in the market, for proprietary junk like so called passive PoE devices.
