AlbNet
Jul 20, 2017Apprentice
R8000 ensemble mode with Wac730?
Is it possible to have 3 x WAC730 set up in ensemble configuration when directly connected to a R8000 router? Or would this require a switch?
- Jul 21, 2017
If all three APs are reachable to each other (pingable) then it should work.
If you have not seen this video then I would recommend this.
https://www.youtube.com/watch?v=2ZGKqay5cqo
Thanks
Raghu
RaghuHR
Jul 20, 2017NETGEAR Expert
Are all those 3 WAC730s in the same network? Then yes. Can you show us your network diagram so that we can confirm.
- AlbNetJul 21, 2017ApprenticeYes, the 3 APs are in a single network and directly attached to the router as follows:
modem --> R8000 --> 3xWAC730 (each one attached to one of the Ethernet ports of the router).
Essentially the question is if R8000 can handle ensemble set up- RaghuHRJul 21, 2017NETGEAR Expert
Thanks
Raghu
