AlbNet
Jul 20, 2017Apprentice
R8000 ensemble mode with Wac730?
Is it possible to have 3 x WAC730 set up in ensemble configuration when directly connected to a R8000 router? Or would this require a switch?
- Jul 21, 2017
If all three APs are reachable to each other (pingable) then it should work.
If you have not seen this video then I would recommend this.
https://www.youtube.com/watch?v=2ZGKqay5cqo
Thanks
Raghu
RaghuHR
Jul 20, 2017NETGEAR Expert
Are all those 3 WAC730s in the same network? Then yes. Can you show us your network diagram so that we can confirm.
