AlbNet
Jul 20, 2017Apprentice
R8000 ensemble mode with Wac730?
Is it possible to have 3 x WAC730 set up in ensemble configuration when directly connected to a R8000 router? Or would this require a switch?
- Jul 21, 2017
If all three APs are reachable to each other (pingable) then it should work.
If you have not seen this video then I would recommend this.
https://www.youtube.com/watch?v=2ZGKqay5cqo
Thanks
Raghu
AlbNet
Jul 21, 2017Apprentice
Yes, the 3 APs are in a single network and directly attached to the router as follows:
modem --> R8000 --> 3xWAC730 (each one attached to one of the Ethernet ports of the router).
Essentially the question is if R8000 can handle ensemble set up
RaghuHR
Jul 21, 2017NETGEAR Expert
Thanks
Raghu
