cmarcera
Feb 09, 2024Follower
RAX50 + WAX214v2 Compatibility
I live in a 2,800 square foot ranch with a finished basement (1,400 upstairs, same footprint downstairs) and my cable modem comes in the house in the middle of the lower floor. All rooms have Cat6 ja...
Feb 09, 2024Guru - Experienced User
Why not simply go with something like the Netgear MK93?
It supports wired backhaul and has 2.4/5/6ghz.
It'll make a decent mesh versus trying to mix-match a consumer router with a quasi-business class one.
And it'd come in well cheaper than the $1k price point.
Easier setup as you're only managing a single system.
Easier roaming/fast roaming/bandsteering
Has 6ghz.
Not sure why you're looking at the RAX50/WAX214 setup
- Oct 01, 2020Retired_Member
