mhndsh
Mar 25, 2018Aspirant
Disable WG103 Rogue AP is better?
Hi, Is it better for AP performance to disable Rogue AP feature if i'm not using it? Thanks
- Mar 27, 2018
Hi mhndsh,
As far as I have checked, the performance of the WG103 is not affected even if the Rogue AP Detection is turned on. It would be best to turn on Rogue AP Detection because unknown APs and wireless stations are prevented from connecting to the WG103.
Kindly read pages 4-19 to 4-20 of the WG103 reference manual here about Rogue AP Detection.
DaneA
NETGEAR Community Team
DaneA
Apr 03, 2018NETGEAR Employee Retired
"because unknown APs and wireless stations are prevented from connecting to the WG103."
How does that happen? How does WG103 determine that this station is harmful?
If you will observe, the MAC Address, SSIDs and its corresponding channel(s) are detected and shown in the Unknown AP List. With regard to this, you will be able to identify if the wireless networks detected in the Unknown AP List are suspicious or not.
DaneA
mhndsh
Apr 03, 2018Aspirant
so, if the device (mobile device) is in the Rogue list it will not be able to access the AP? (this is not clear in the reference manual)
Thanks for your help
