kortina
Mar 28, 2023Aspirant
Laptop not switching to closer WAX610 access point automatically
I have 2 WAX610 Access Points, one on my 1st floor, one on my 2nd floor. I opened my laptop on the first floor, then went upstairs to the 2nd floor to the same room (about 6ft away) from the 2nd ...
kortina
hnagaraju1 thanks for the links / advice.
I actually use 802.11r and the Insights app says not to turn on Band Steering (802.11k RRM and 802.11v) if you are using 802.11r
Maybe I will try adjusting the power of one of the APs to reduce collisions.
nmhTester
Mar 28, 2023NETGEAR Employee Retired
use the https://insight.netgear.com
webUI to see more options to configure and monitor.
Insight APP is a great tool to monitor network.
