Coffee-man
Nov 28, 2020Aspirant
Recommend best business router/solution
I need to be able to handle 3 secure seporate networks on the same IP for a coffee shop. My IPS doesnt allow multiple IP's. One network needs to be for POS only, other for all of the smart devices on...
smath
Nov 29, 2020Initiate
Dear Coffee-man
Please check out https://community.netgear.com/t5/Business-Wireless/Create-a-Secure-WiFi-6-Bubble-with-Business-AP-WAX204/m-p/2010798
WAX204 is a latest NETGEAR's WiFi-6(11ax) access point+router and looks ideal for your requirement.
Refer WAX204 documents @ https://www.netgear.com/support/product/wax204.aspx#docs
Thanks
Sharan
Coffee-man
Nov 30, 2020Aspirant
Looks promising! But i also have some USB devices currently plugged in into routers? Will there be a way for me to plug in USB devices? Is there any hun available? Thank you!
- smathNov 30, 2020Initiate
- Coffee-manDec 04, 2020Aspirant
Is the the only device I would need to build the netwrok? Woud I need any additionla routes or swiches? Will I be able to add any additional newtwork extenders, ap's to it?
