RAJordao's avatar
RAJordao
Follower
Apr 25, 2017
Setting up a Wifi for 200 devices
Hi,   I`m having trouble finding information about Netgear products.   I`m trying to set up a Wifi zone in my small business to allow 200 devices to connect simultaneously, however I can`t find w...
  • nmhTester's avatar
    nmhTester
    Apr 26, 2017
    Dear Rodrigo,
    Thank you for choosing Netgear. We have mutiple products that are perfect value for SMB deployments.
    Here is the product selector, that give different Management options.
    http://selector.netgear.com/productsearch/FormProductSelector.aspx?categoryid=1003&LanguageCode=en-US
    Other points to consider are:
    Number of AP to deploy depends on floor plan , per client data rates,  client density  per AP you need.
    The exact AP model to buy depends on what kind of management will fit your needs and feature like captive portal/Guest access.
    Couple of suggestions:
    1) WC7500-WAC730 or WAC720 is great combination.
    2) WAC730/WAC720 standalone:  v3.7.x supports Facebook wifi, incase you want to drive wifi users to the companie's facebook page.
    For  basic deployments,
    WAC510 deployed at right places will work too.
    Orbi also an alternative option. http://blog.netgear.com/blog/orbi-for-small-business/
ProSupport for Business
