slamers74
Apr 09, 2020Aspirant
WAC510 - date/time stamp on notifications
I've noticed the date stamp on the notification is behind by 1 day. I have double checked that the date is correct and it setup to automatically use the netgear time server. While it is not crit...
- May 10, 2020
As requested, I made the firmware update (that you made available to me) and the time stamps in the notification window now match with the correct local/current time.
Thank you for your support!
slamers74
Apr 10, 2020Aspirant
I will certainly do that, however the dates are correct in the monitoring log, just not in the pop up display.
Again - not urgent for me personally, but though it might be something that should be looked at.
slamers74
May 10, 2020Aspirant
