mmmix
Apr 08, 2017Guide
R8000 Date and Time incorrect
Firmware Version
V1.0.3.36_1.1.25
Just cannot get this router to set the correct date and time from the internet, which makes the scheduling function useless. Tried all the other suggestions mentioned on the forums like setting NAT to open and resetting to factory, nothing works. Am using OpenDNS for family settings, but I tried a number of other DNS providers just in case. Nothing works.
Hi mmmix,
Have you tried this firmware?
https://kb.netgear.com/000038688/R8000-Firmware-Version-1-0-3-46
Reset it after the update.
- William10aMaster
What modem and isp are you using ATT and the netgear router not setting the correct time and date have been posted before?
- mmmixGuide
It's Comcast with an Xfinity modem TG862G set in bridge mode
- William10aMaster
It should be able to go out on the web and pull the time and date in for the router use.
If you keep the WNDR as the main host router and want to use the R8000 behind it, be sure to use the DMZ on the WNDR for the IP address it gives the R8000. However I recommend swapping around routers like William mentioned.
What will adding the r8000's IP address(192.168.1.2) as a DMZ on the WNDR(192.168.1.1) accomplish?
Allow all ports and traffic unhinder by the WNDR router, to the R8000 router. Sometimes I do then when testing two routers in line. Helps with double NAT issues in this configuration.
