Preformed2019
Mar 31, 2022Tutor
WAC540 WIFI Scheduling issue
Hello guys I have 5 WAC540 AP devices, which I need to set a scheduled SSID availability. there is an option on the SSID setting to set a schedule and it will let you choose the time you want to se...
schumaku
Mar 31, 2022Guru - Experienced User
Very unlucky schedule specs for your use case. RaghuHR - discussed several times already - scheduling requires a complete redesign (local and Insight).
Preformed2019
Mar 31, 2022Tutor
totally agree, it's bad design and need to have all day option. for now I have stopped using the SSID schedule as it is useless for my case.
if you have any update let me know.
thanks for your response.
