redtech116
Jan 28, 2017Aspirant
WAC720 LOCKING UP
Having a radom lockup issue...on two different wac720 units at different sites the wireless just stops, can not log into the unit, disconnect/reconnect ethernet has no effect. Have to power cycle ...
redtech116
Feb 01, 2017Aspirant
why can I not attach a file here...? I can attach a picture but not a file..come on NETGEAR
the AP completely locks up , can not log into it wirelessly or wired...
some are on the 5 some are on the 2.4 radio's..take your pick..
this is about all i can give anyone..
https://www.dropbox.com/s/40z7qcprc0g7rlo/config.xml?dl=0
DCMData
Mar 07, 2017Tutor
I would like to get in on this, I am having the exact same issue. All the lights stay on but it kicks everything off. We have 1 garage door opener, 3 asus laptops, 2 android phones, a ring door bell, and ring door bell speaker and that is it.
I also thought it was a hardware issue so Netgear replaced mine, got the new one programmed and same issue started again.
- RaghuHRMar 07, 2017NETGEAR Expert
Hi DCMData
Are you able to login to AP UI? If yes Could you please send us the AP logs? We will take a look at it.
Are you seeing all LEDs are solid Green and not blinking?
Thanks
Raghu
- DCMDataMar 07, 2017Tutor
Yes all lights are solid, not blinking. Sometimes traffic light is off, next to the power light, but that is 1 out of every 10 times. Sometimes it will stay up for days, some days I reset it 6 times a day. Today I have reset it 3 times so far.
When it freezes there is no logging into it, I cannot ping it or anything from a hardwire connection on the network. Other things I have tried is different POE injectors and a POE switch, thinking it was a power thing. It is not where I can plug it in to an outlet.
This is all that is in the logs right now...
[Mar 8 2017 02:11:59] [info] hostapd[1345] STA 00:1d:c9:29:6c:22 associated with BSSID 2c:30:33:98:8f:a0
[Mar 8 2017 02:11:59] [info] hostapd[1345] Assoc request from 00:1d:c9:29:6c:22 BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 8 2017 02:10:57] [info] hostapd[1345] STA 74:f0:6d:20:4d:08 associated with BSSID 2c:30:33:98:8f:a0
[Mar 8 2017 02:10:57] [info] hostapd[1345] Assoc request from 74:f0:6d:20:4d:08 BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 8 2017 02:10:54] [info] hostapd[1345] STA fc:c2:de:8f:10:41 associated with BSSID 2c:30:33:98:8f:a0
[Mar 8 2017 02:10:54] [info] hostapd[1345] Assoc request from fc:c2:de:8f:10:41 BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 8 2017 02:10:46] [info] hostapd[1345] STA d0:22:be:f5:50:0f associated with BSSID 2c:30:33:98:8f:a0
[Mar 8 2017 02:10:46] [info] hostapd[1345] Assoc request from d0:22:be:f5:50:0f BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 8 2017 02:10:45] [info] hostapd[1345] STA 64:52:99:48:26:5d associated with BSSID 2c:30:33:98:8f:a0
[Mar 8 2017 02:10:45] [info] hostapd[1345] Assoc request from 64:52:99:48:26:5d BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 8 2017 02:10:42] [info] hostapd[1345] STA c0:56:27:4e:4b:e6 associated with BSSID 2c:30:33:98:8f:b0
[Mar 8 2017 02:10:42] [info] hostapd[1345] Assoc request from c0:56:27:4e:4b:e6 BSSID 2c:30:33:98:8f:b0 SSID ComeTakeIt5G
[Mar 8 2017 02:10:37] [info] hostapd[1345] STA f4:b8:5e:4d:5e:5b associated with BSSID 2c:30:33:98:8f:a0
[Mar 8 2017 02:10:37] [info] hostapd[1345] Assoc request from f4:b8:5e:4d:5e:5b BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 8 2017 02:10:35] [info] hostapd[1345] STA dc:85:de:89:12:ff associated with BSSID 2c:30:33:98:8f:a0
[Mar 8 2017 02:10:35] [info] hostapd[1345] Assoc request from dc:85:de:89:12:ff BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 8 2017 02:10:27] [info] dman[1107] SSL certificate generated for Clusterd
[Mar 8 2017 02:10:27] [err] mDNSResponder mDNSPlatformRawTime went backwards by 989200818 ticks; setting correction factor to -127739691- RaghuHRMar 07, 2017NETGEAR Expert
Thanks for the info. I think these logs are taken after the AP reset. Do you have any external syslog setup? Please share the logs before the reboot.
Raghu
