dhda
May 23, 2022Aspirant
WAX610 needs reboot daily, before clients can connect
Approaching the WAX610 AP, WIFI Analyzer shows the strong signal (-40dB) but Android as well as Windows clients do not connect, not even after switching OFF/ON WIFI. They remain on an AP, too far aw...
schumaku
May 25, 2022Guru - Experienced User
dhda wrote:
What do you mean with send link via PM (to provide you the log) ?
Put the log file(s) on any kind of cloud storage which allows to share files using a simple link.
dhda
May 25, 2022Aspirant
In the meanwhile, here's a link of the logfile, after the AP had been restarted : https://1drv.ms/u/s!Ai4PEQfZRtEfgpBcD7nbTJ_G7V_I-w?e=1kuqJY
About 7 clients have been connected since, before this remained 0 clients.
Hope the logfiles can clear something out.
- RaghuHRMay 25, 2022NETGEAR Expert
Hi dhda
I think you are roaming between two APs...P IP ...101 to AP IP ...249 Could you please provide the detailed logs of both the APs? AP IP ...101 and AP IP ...249?
Thanks,
Raghu
- dhdaMay 25, 2022Aspirant
Just realised, the logging of the other AP (IP 101) covers the whole period, cause it hasn't been rebooted since the morning.
This means the test around 12:45, trying to connect, moving from 101 to 249 is in the log, as well as the test and the reboot of 249 later on, after which everything connected to it.
Link to the log of 101 : https://1drv.ms/u/s!Ai4PEQfZRtEfgpBdw2aFW_R60PkPcg?e=wOqrp1
In the meanwhile, AP with IP 101 seems getting IP 154.
Best Regards (and enjoy the long weekend ?)
- dhdaMay 31, 2022Aspirant
May I ask if the latest log maybe could clarify a little more ?
In the meanwhile, there was one day the AP didn't has to be rebooted (!?), but all other times, number of clients remained 0 (according to insight and also the weak connection on the client), untill the AP had been rebooted.
Thanks in advance.
