Robert_Fernando
Jul 27, 2016Aspirant
Remotly rebooting a wnap320
Hi all, Is itr possible to send a packet across the network to a wnap320 ap to reboot it. I like to use spiceworks network monitoring tool to detect when the wireless radios / ssids have gone of...
- Aug 26, 2016
To reboot wnap320
using
puttyconfig new putty entry
ip address of ap
type ssh
when ssh session starts
type at the prompts1: login name AP
2: password of AP
3: command reboot
Typical output
ph1 is the name of the AP
login as: y
[email protected] password:
ph1#reboot
Robert_Fernando
Aug 15, 2016Aspirant
Hi all,
I found using ssh I could connect to the netgaer wnap320 and issue the reboot command
Robert
DaneA
Aug 16, 2016NETGEAR Employee Retired
Hi Robert_Fernando,
I appreciate the update. Can you share here on this forum thread the exact steps you have done for the benefit of other community members?
Is your WNAP320 access point now working fine?
DaneA
NETGEAR Community Team
