Robert_Fernando
Jul 27, 2016Aspirant
Remotly rebooting a wnap320
Hi all, Is itr possible to send a packet across the network to a wnap320 ap to reboot it. I like to use spiceworks network monitoring tool to detect when the wireless radios / ssids have gone of...
- Aug 26, 2016
To reboot wnap320
using
puttyconfig new putty entry
ip address of ap
type ssh
when ssh session starts
type at the prompts1: login name AP
2: password of AP
3: command reboot
Typical output
ph1 is the name of the AP
login as: y
[email protected] password:
ph1#reboot
JohnRo
Aug 19, 2016NETGEAR Employee Retired
Hi Robert_Fernando,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
Robert_Fernando
Aug 26, 2016Aspirant
To reboot wnap320
using
putty
ip address of ap
type ssh
type at the prompts
1: login name AP
2: password of AP
3: command reboot
Typical output
login as: y
ph1#reboot
- DaneAAug 28, 2016NETGEAR Employee Retired
Hi Robert_Fernando,
I really appreciate you've posted the steps on how to reboot he WNAP320 via SSH. This will benefit the community members. :)
Cheers,
DaneA
NETGEAR Community Team
