mspeculatrix
Jun 25, 2022Guide
routerlogin.net page rendering blank
I'm trying to set up a WAC564 that I haven't used in a while. I've factory reset it (more than once). Its access point (NETGEARxxx-SETUP) appears okay and I can connect to that. But when I go to www.routerlogin.net, I just get a blank page. The page is actually downloaded – I can see the code in developer tools in the browser, but it renders as a blank page.
I've tried this on my iPhone (Safari and Firefox), iPad (same browsers) and my MacBook (Firefox, Chrome, Safari and Vivaldi) all with the same result.
Any odeas how to make this invisible page visible?
Have you tried on a windows pc?
Also, make sure on the mac/iphone that icloud relay and private mac/ip address are disabled.
I tried Edge in a Win11 VM. Same result. It's not a routing problem because I am getting the page code. It's just not rendering correctly.
I should add that, if I leave the blank white page loaded, after a while I get a message about some kind of time-out and the page reloads – I think to some kind of login. But it's still just blank, so hard to tell.
Okay, this is weird. Still getting a blank page at www.routerlogin.net. By if I go to 192.168.0.100 I get a login page. Trouble is, I've no idea what the password is.
I've done a reset three times now - getting the rapidly flashing amber light each time. Shouldn't that have cleared the password and reset to 'never been used' mode?
