excellcomm
Jan 04, 2023Follower
Samsung smartphones disassociating from WAC510
Hello, just wondering if this is a known issue or if I need to troubleshoot further. I have WAC510 units deployed across multiple sites, all Insight-managed. It seems that ever since the most recent ...
Jan 04, 2023Guru - Experienced User
Apple and now samsung have been using a private mac/ip address setting for "security".
You can check and see if disabling that on the devices helps stability.
