Accuphaze
Jul 26, 2021Aspirant
Scheduling for fix canal 5G
Hello! If scheduler is enabled, it incorrectly saves a fixed channel on 5G. Instead of 44 or 48, 36 is set. To set a fixed 44 or 48, you need to disable the scheduler! Correct your mistake. I.e. it is impossible to use the scheduler. I tried to do a reset - it does not fix the problem.Thanks.
Netgear WAX610PA-100NAS
f/w ver 9.5.2.5
s/n 6AB40B2G01778
There are two kinds of schedulers on the WAX6xx: A scheduled reboot, and the ability to enable/disable each network (by SSID) individually on a schedule.
Assume you talk of the reboot schedule, this reads to me like the manual wireless channel setting isn't take into consideration, and the default channel is used.
Curious, does the same happen on manually reboot the WAX610 - being using warm reboot (UI -> Reboot) or cold (cut and reapply PoE/power)?
Keep in mind you talk to the communty here, so it's neither my firmware nor my mistake.
RaghuHR please.
- AccuphazeAspirant
Scheduler for SSID (disable Wifi 5G 23.00-08.00).
