Marhan05's avatar
Marhan05
Setting up a small WifI network using WNDAP360's
Would someone be able to give me some info on how to set up my WiFi network please ?   I'm trying to achieve a small WiFi network consisting of one Netgear D7800 router and 3 Netgear WNDAP360 acces...
  • JeraldM's avatar
    Aug 04, 2022
    Hi Marhan05,
    It is possible to setup the WNDAP360s to have client devices connect from one AP to another by configuring the APs with the same SSID as you said.
    However, the APs are fairly old and you may notice some delay when client devices switch from one AP to another.
    For your reference, kindly check this community thread.
    JeraldM
    NETGEAR Community Team
ProSupport for Business
