scliffe
Sep 22, 2016Aspirant
SNMP wlan utilization rate
I'm trying to understand the hrSysWlanUtilizationRate SNMP object. The description in the MIB file says "the field indicates the wlan Utilization Rate based on calculating station access Time" so I ...
kohdee
Oct 05, 2016Administrator
Just curious, is that correlating with your AP's uptime?
- scliffeOct 05, 2016Aspirant
A good suggestion, but no. My AP has been up for almost a week and this is occuring regularly 2-3 times/day:
[UDP: [192.168.128.254]:161->[0.0.0.0]:42517]=>[Linux wlan-ap 2.6.23-WNAP320_V3.5.6.0-g0c2ca724 #1 Tue Apr 12 03:19:54 PDT 2016 mips] Up: 6 days, 17:57:42.78
- RaghuHROct 18, 2016NETGEAR Expert
Can you please tell me the application name that you are running to measure WLAN utilization?
When AP fails to fetch values from database this can happen.
- scliffeOct 18, 2016Aspirant
I'm using collectd (https://collectd.org/) with the SNMP plugin. I'm also collecting WLAN clients and CPU utilization from the AP and these graphs look fine.
