coxbuell
Mar 23, 2016Tutor
Specific need
Hello, I'm working on a global set installation which needs to have some RJ45 and wi-fi connections (for a closed network). 10 x RJ45 materials. 2 x wi-fi materials. I need a rack solution. This...
- Mar 23, 2016
Hello coxbuell,
You're welcome, I hope that the FVS318N will cover all that you need. That's an interesting network you're trying to build.
If one of my replies has helped you fix or give answers to your issues please mark it as "accepted solution". Let us know if you have more questions.
Thanks,
JohnRo
Mar 23, 2016NETGEAR Employee Retired
Hello coxbuell,
Welcome to the community!
You'll probably need a switch and some APs (Access Points) if that is the case. What kind of environment are you planning to build you network on? Do you already have routers/firewalls or DHCP servers in place?
Looking forward to your response.
Thanks,
