coxbuell
Mar 23, 2016Tutor
Specific need
Hello, I'm working on a global set installation which needs to have some RJ45 and wi-fi connections (for a closed network). 10 x RJ45 materials. 2 x wi-fi materials. I need a rack solution. This...
- Mar 23, 2016
Hello coxbuell,
You're welcome, I hope that the FVS318N will cover all that you need. That's an interesting network you're trying to build.
If one of my replies has helped you fix or give answers to your issues please mark it as "accepted solution". Let us know if you have more questions.
Thanks,
JohnRo
Mar 23, 2016NETGEAR Employee Retired
Hello coxbuell,
Welcome to the community!
You'll probably need a switch and some APs (Access Points) if that is the case. What kind of environment are you planning to build you network on? Do you already have routers/firewalls or DHCP servers in place?
Looking forward to your response.
Thanks,
coxbuell
Mar 23, 2016Tutor
Hi,
Thanks for your answer.
I don’t have any router or DHCP in place yet.
I just have few machines which need to communicate via RJ45 (computers, contacts I/O, DMX lights, Wi-Fi tablet control).
No access to Internet, just closed network.
Most of machines are in a bay 19’’.
I think I need a rack router Wi-fi with 10 x RJ45.
But I don’t know which one to choose?
Do you have an optimized suggestion?
Thanks for your help.
