jpullam
Aug 09, 2016Guide
technical details on external antennas
I just bought a WN203 because I want to significantly improve the wireless in my home/office (currently using a Bell ConnectionHub modem). The documentation says that I can add 2 external antennas to...
JohnRo
Aug 12, 2016NETGEAR Employee Retired
Hi jpullam,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
