Julien_A
Dec 12, 2024Tutor
TLS 1.0 & 1.1 active in WAX625 https web interface
Having TLS 1.0 and TLS1.1 supported in https web interface makes Wifi WAX product line susceptible to TLS attacks : - BEAST Attack - CRIME Attack - RC4 Attack - Weak Cipher Suites Attack - Atta...
schumaku
Dec 13, 2024Guru - Experienced User
Curiosity question back on the subject:
Are you operating a PKI and deploy fully signed and certificates signed by a trusted CA to an environment with a full DNS coverage?
Reason asking: We need (much) more pressure on Netgear enhancing many more details, raising more awareness. with the NTGR engineering and management.
Certainly, Netgear does understand on how to run some vulnerability checking I assume.
- Julien_ADec 13, 2024Tutor
schumaku a écrit :Are you operating a PKI and deploy fully signed and certificates signed by a trusted CA to an environment with a full DNS coverage?
Exactly ! but deploying such certificate for "web management" is a "second step" for us, first immediate step would be to stop using legacy TLS protocols (and/or cipher suites).
so
(1) have a security setting I could untick: [ X ] Legacy TLS support 1.0 1.1
(2) be able to generate a correct CSR (with hostnames/fqdn/etc.. as S.A.N.) to create its certificate with a PKI
- schumakuDec 13, 2024Guru - Experienced User
hnagaraju please join this discussion - there is a lot of work waiting overdue for a long time
- Julien_ADec 20, 2024Tutor
Should I conclude that netgear products are not oriented for professional usage ?
And netgear don't care at all about security ? (oh maybe they slooooowwly care)
I'm a bit disappointed, there's not that much that's missing, and product quality is way better than the Dlink we previously tried (in the same range of price).
