Sherminator
Jun 08, 2018Tutor
Turn off RADIUS on WAC720
Hi there,
we discovered some unexpected RADIUS traffic on our network (UDP port 1812/1813) and identified our WAC720 as the source. We don't use RADIUS, so we like to turn it off. What's the be...
- Jun 10, 2018
RaghuHR
Jun 08, 2018NETGEAR Expert
Hi Stephan ,
Welcome to the Netgear Community. Could you please help us share more details with packet captures? Are you seeing that AP is sending radius packets without enabling it?
Share the detailed from logs from monitoring page. We will take a look at it.
Thanks,
Raghu
- SherminatorJun 08, 2018Tutor
Hi Raghu,
thanks for your fast answer!
Our firewall logs show that the APs try to send RADIUS packets to the ip address 192.168.1.1, which is an existing device in our network. So I went into the GUI of the AP an realized that 192.168.1.1 seems to be the default entry for RADIUS. So I searched for a way to turn RADIUS off, but didn't succeed. Then I tried to blank these fields, but that's not possible. So I'm looking for the best way to "silence" RADIUS on the APs.
Greets
Stephan
