hg83
Oct 09, 2015Guide
Unable to reach ProSafe WN203 access point
My WN203 has been reset to factory settings. Updater to 2.0.11 firmare version Changes IP address to DHCP mode. Management screen shows up all right on my Mac Changed Antennas to "external" Chan...
- Nov 03, 2015
Works now with channel 1!! Had tested 6 and 11!!
Case closed
Thanks
Henri
hg83
Oct 09, 2015Guide
The WN203 Acces Point is correctly connected to my LAN as I can verify that the "time" value updates correctly.
Henri
- JohnRoOct 09, 2015NETGEAR Employee Retired
Hello hg83,
Welcome to the community!
I see you have some issues connecting your MAC to your WN203 AP, let me try to help you. I have some questions before I start giving troubleshooting tips, this will help me give you a more accurate troubleshooting to fix your network problem. I have listed my questions below:
1. How far/close are you from the AP?
2. Does other devices on the network experience the same issue?
3. Why was the AP been reset to factory default?
4. What channels are you using?
5. What is the version of your MAC?
Looking forward to your response.
Thanks,
- hg83Oct 10, 2015Guide
Hello,
here are the answers to 5 questions:
1/ Very close, three feet
2/ The remainder of the network works fine (Airport time capsule, ADSL router box with WiFi capability)
3/ Lost passwords/keys following change of admin ownership
4/ Default values (11ng, Channel/Frequency = auto)
5/ iMac and MacBook Air whith latest system (10.10.5)
Thanks for help
Henri
Today, I dont see the SSID any more!! The radio side of the box seems broken!!
Cheers,
Henri
