hg83
Oct 09, 2015Guide
Unable to reach ProSafe WN203 access point
My WN203 has been reset to factory settings. Updater to 2.0.11 firmare version Changes IP address to DHCP mode. Management screen shows up all right on my Mac Changed Antennas to "external" Chan...
- Nov 03, 2015
Works now with channel 1!! Had tested 6 and 11!!
Case closed
Thanks
Henri
Aldair
Oct 13, 2015Aspirant
I have one simple suggestion.
Change the channel of your access point to 1, 6 or 11...
I remember when i installed WN203 at my company, some macbooks did not work by this way, and then i changed the channel and everything works very well..
You can try using another computer to connect.
Best Regards.
JohnRo
Oct 13, 2015NETGEAR Employee Retired
Hello Aldair,
Yes, that is a good suggestion since some devices are more comfortable locking with the channels mentioned. However, we'll have to wait for OP's response regarding the status of the switch. We'll need to know if it is still active before we can probably try changing the channels.
Thank you for your contribution.
