hg83
Oct 09, 2015Guide
Unable to reach ProSafe WN203 access point
My WN203 has been reset to factory settings. Updater to 2.0.11 firmare version Changes IP address to DHCP mode. Management screen shows up all right on my Mac Changed Antennas to "external" Chan...
- Nov 03, 2015
Works now with channel 1!! Had tested 6 and 11!!
Case closed
Thanks
Henri
JohnRo
Oct 13, 2015NETGEAR Employee Retired
Hello Aldair,
Yes, that is a good suggestion since some devices are more comfortable locking with the channels mentioned. However, we'll have to wait for OP's response regarding the status of the switch. We'll need to know if it is still active before we can probably try changing the channels.
Thank you for your contribution.
hg83
Oct 17, 2015Guide
No broadcast of SSID at this time.
Test made with iMac and MacBook AIr.
Haven't figured out yet how to change channel number.
Problem is now lower priority (hence my silence lately). Will come back to it later
Cheers,
Henri
- JohnRoOct 19, 2015NETGEAR Employee Retired
Hi hg83,
You can change the channel by going to Configuration > Wireless > Basic > Wireless Settings. See image below for reference:
See page 26 of the manual, click here:
Thanks,
- hg83Nov 01, 2015Guide
Last effort! Even after selecting various channels, the SSID of the box remains invisible!!
I fear the radio aprt of the box is dead!!
Cheers
Henri
- JohnRoNov 02, 2015NETGEAR Employee Retired
Hi hg83,
Please try uploading the image again, it looks like it wasn't uploaded properly. I suggest contact the support team, if determined a problem with the radio it should be covered under warranty.
Thanks,
- hg83Nov 02, 2015Guide
Repeat :
The box talks OK over ethernet, but does not show any SSID visible from a iMac, a MacBook Air and an iPhone 6.
Radio is broken????
Cheers,
Henri
- AldairNov 03, 2015Aspirant
Hello Hg.
Are you tryed with another device with another OS??
It's can be a speficial issues with apple devices. Try to connect another equipment...
Go to Configuration >> Wireless.. When you pass through the channel( 11ng ) you see something like " Radio is set 'ON' " ??
You already change the channel to 1 or 6 or 11?
Keep yourself on Configuration >> Wireless.. The option to broadcast SSID is enable with option YES?
Go to Configuration >> Security... The SSID that you configured is checked on ENABLE fields?
Those questions can be obvious, but all detail are important.
Best Regards.
- hg83Nov 03, 2015Guide
Case closed
Thanks
Henri
