garyroute
Apr 18, 2020Tutor
UPnP on the WAC720
Hi I have a WAC510 and the WAC720. The issue is that the WAC510 will forward UPnP packets and the WAC720 will not. Is there any way to configure the WAC720 to pass UPnP packets. Maybe through the CL...
garyroute
Apr 20, 2020Tutor
Success! Keeping WMF disabled allows pywemo discovery to work every time.
So from the config example I see a separate SSID for IGMP_Snoop with WMF enabled. If I need IGMP on the WAC720 in the future I will setup a separate SSID.
Thanks so much.
Gary
