JEDIV
Aug 25, 2022Apprentice
WAC 510 - Flaky Connectivity and Behavior - Is it failing?
Hi, I have a WAC 510 that has been behaving strangely for several months now. It is located in the attic above the garage in an area that can be quite hot during the summer, but I'm not sure that is...
DaneA
Sep 07, 2022NETGEAR Employee Retired
What NETGEAR Insight subscription do you have? Is it Insight Premium or Insight Pro?
Does the WAC510 have Insight credits?
What is the current firmware version of the WAC510?
DaneA
NETGEAR Community Team
DaneA
Sep 15, 2022NETGEAR Employee Retired
What is the current version of your NETGEAR Insight App? If ever its not yet the latest version, I suggest you to update it to NETGEAR Insight v6.8 then check if the WAC510 will still show "Disconnected" even though its working properly.
DaneA
