n923157
Nov 05, 2021Follower
WAC 510 + C6300 Facebook wifi
I atttached my WAC510 to my home router Netgear Night Hawk AC1750, model R5700 and setup Facebook wifi and it worked as intended (choose WAC's SSID and got directed to page with options to login, Fac...
JeraldM
Nov 09, 2021NETGEAR Employee Retired
Welcome to the community!
It should work since both R6700 and C6300 function as routers.
Having that said, you can try performing a reboot or reset (if possible) on the WAC510 while connected to the C6300 to see if that resolves the issue.
Have you also tried connecting multiple devices to the WAC510 while it's wired to the C6300?
JeraldM
NETGEAR Community Team
