javier_perez
Nov 16, 2018Aspirant
WAC 720 hard RESET
Hello All
due to a posible loop error on the network (i dont sure about that yet), i lose contact with the WAC 720 in the configured IP, so i do hard reset to the device, connect through 192.16...
- Nov 16, 2018
javier_perez Please select the check box cloud enabled to No and it will go for standalone mode after the reboot.
Then you can restore the config.
Thanks,
Raghu
RaghuHR
Nov 16, 2018NETGEAR Expert
Thanks,
Raghu
javier_perez
Nov 19, 2018Aspirant
Thank you.....now all is working again!
