minetpro
Oct 25, 2018Aspirant
WAC 730 and Ensemble Mode, cannot join third AP when without LAN Connection
Hello there, I'm thinking of someone having the same Problem as we have. I shortly explain the Situation: We own a Internet Router which is connected to a netgear Poe-Switch. On the Poe Switch 2 LAN ...
- Oct 26, 2018
RaghuHR wrote:
Bridging is another soultion can provide you extension your network to different floor or building.
This is what was configured in my understanding, as there is no Extender mode on the WAC730. I don't thingk the OP was so blue-eyed that it works without a configured wireless bridge. But then we're at the same point - in my L2 understanding, the wireless bridge would make another segment, like the LAN segment on the detached WAC wold create a third L2 segment.
Do you expect that multiple WAC730 in wired and bridged config would allow to operate as a single Ensemble?
