Owl37's avatar
Owl37
WAC104 - Devices won't connect to wifi
Hi,
Having recently purchased the WAC104, I followed the set up instructions using my smartphone. I went to the www.aplogin.net page and set a new password. Having done this I then tried to connect to the wifi using my smartphone but it keeps saying 'failed to obtain IP address'.
I then used my personal laptop to connect to the WAC104 using the ethernet cable. This worked and enabled me to get to the setup page. I checked to see if there was a firmware update available but there wasn't. The firmware version is V1.0.4.17. I re-entered the password I had used before to see if this would do anything and applied the changes.
I tried to connect my phone again but it's still saying 'failed to obtain IP address'.
I also tried connecting my work laptop (which doesn't have an ethernet cable port) via the wifi and it is saying 'no internet secured'.
I'm not sure what to try next so any help would be much appreciated.
Thanks.
Owl37
  • schumaku's avatar
    schumaku
    What password? Probably the admin login password, required to access the WAC104 Web UI.
    Have used the network name published, and the network key or preshared password as defined by default? Keep in mind there are different "passwords".
    An Access Point requires a network (Ethernet) LAN connection to the local network, connecting to the router typically. There is a DHCP server, which in general is able to assign a free IP address from that LAN DHCP server. Just a connection smartphone<->WAC104<->notebook does not make a fully workable network. It should be for example smartphone<->WAC104<->Router LAN POrt.
    secured'.
    Lack of any router and Internet connection one would guess.
    • Owl37's avatar
      Owl37
      Thanks for the help, I realised that the when the ethernet cable was plugged in to LAN1 the green light wasn't showing, I moved it to LAN4 and the green light is on and it now works.
ProSupport for Business
