Retired_Member
Nov 18, 2017WAC104 GUI text file Update Fails
Hello, I have the WAC104 – Dual Band 802.11ac Wireless Access Point, I have the latest firmware. However, everytime I check for an update it gives the following. There is a new GUI text file...
- Nov 20, 2017
Hi Liam Scorziello,
Could you please check now and see if you are seeing the same repetative message?
Thanks
Raghu
RaghuHR
Nov 20, 2017NETGEAR Expert
Hi Liam Scorziello,
Thanks
Raghu
Retired_Member
Nov 20, 2017Hi Raghu,
I have checked, and its no longer saying the GUI Update is available, thanks for your help, much appreciated.
Liam Scorziello
