Eddizzo
Oct 17, 2022Aspirant
WAC124 Disconnected when Sync with NTP Server - SECOND :D
Hi at All, It's my first post on this forum even If I read a lot of topic in past. In this case I would like to ask support in something similar what was discussed on this topic: "WAC124 WLAN...
DaneA
Oct 18, 2022NETGEAR Employee Retired
Let us isolate the problem. Kindly try to connect the WAC124 (in Access Point mode) directly to the Vodafone router. Be sure that the WAC124 is on the latest firmware version. Then, try to use the default NETGEAR NTP Server and observe if the same problem will occur. Also, you may try using other NTP Servers and observe if the same problem will occur.
Another suggestion is try to set the WAC124 in Router mode and set it as the main router connected directly to the modem. Be sure that the SRR60 is on the latest firmware version. Then, try to use the default NETGEAR NTP Server and observe if the same problem will occur. Also, you may try using other NTP Servers and observe if the same problem will occur.
DaneA
NETGEAR Community Team
schumaku
Oct 19, 2022Guru - Experienced User
DaneA in my unqualified understanding, the only VLAN config these WAC10x or WAX124 does support is the router based bridge for IPTV configs. The LAN is supposed to run on an untagged network, and so are the wireless SSIDs. There is no other 802.1q feature available.
