Eddizzo
Oct 17, 2022Aspirant
WAC124 Disconnected when Sync with NTP Server - SECOND :D
Hi at All, It's my first post on this forum even If I read a lot of topic in past. In this case I would like to ask support in something similar what was discussed on this topic: "WAC124 WLAN...
Cookie53
Oct 19, 2022Initiate
Interesting thread, since I have exactly the same problem. I am using my WAC124 as an AP with a static IP connected to a Virgin Media router out to the internet (similar setup to you). I am not sure it is down to the syncing of the NTP server. If I look at my logs it shows the desconnect and reconnect happening sometime later:
[WLAN connection] (0c:9a:3c:64:ad:07) had associated successfully Wednesday, October 19,2022 13:27:38
[WLAN disconnection] (0c:9a:3c:64:ad:07) had deauthenticated Wednesday, October 19,2022 13:27:38
[Time synchronized with NTP server time-g.netgear.com] Wednesday, October 19,2022 12:58:12
[WLAN connection] (0c:9a:3c:64:ad:07) had associated successfully Wednesday, October 19,2022 12:57:30
[WLAN disconnection] (0c:9a:3c:64:ad:07) had deauthenticated Wednesday, October 19,2022 12:57:29
[WLAN connection] (e2:bd:2c:df:94:d8) had associated successfully Wednesday, October 19,2022 12:56:31
[WLAN connection] (0c:9a:3c:64:ad:07) had associated successfully Wednesday, October 19,2022 12:51:18
[Time synchronized with NTP server time-g.netgear.com] Wednesday, October 19,2022 12:51:12
I don't want to hijack the thread, so waiting with bated breath!!
