rafalpil
Jun 12, 2023Aspirant
WAC510 5ghz Connectivity issue
Hello, I do have two WAC505 devices setup in my network. Both are running exactly the same configuration with different SSIDs. Unfortunately I cannot connect to 5Ghz network on one of the devices...
rafalpil
Jun 19, 2023Aspirant
I use Nighthawk X4S R7800 as the main unit for the two WACs that I have.
While I do use MAC DHCP IP assignment, I use it only for my desktops.
The connectivity issue I described only applies to the specific WAC and only 5Ghz network. I can connect fine with the 2,4Ghz network. The coverage of both networks is great when I test it.
I tried with different smartphones, ipad, nintendo switch and the same issue always happens.
