yogensenu
Oct 10, 2022Follower
Wac510 access point set up
How do I set up a wac510 access point the instructions where unclear could not find much on line it has a IP of 192.168.0.1 my network use 192.168.1.1 I use the Netgear insight app can’t get anywhere with it I normally just go to the admin screen and configure stuff that way but I can’t even figure out how to switch the Ip to .1.100 to even get to the admin screen any help would be great
yogensenu wrote:
How do I set up a wac510 access point .....
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads. - schumakuGuru - Experienced User
The IP address is either assigned by the LAN DHCP server e.g. on the router DHCP server, or it was manually misconfigured into a different IP subnet.
Are there potentially two local networks, operated by two different routers, or assigned to two different IP subnetworks?
