NickHW
Jun 05, 2017Aspirant
WAC510 SSID to VLAN association
I read the manual for the WAC510 online and I'm not entirely clear on this point. Does this model permit the creation of virtual access points which map to separate tagged 802.11Q VLANs at the Et...
- Jun 06, 2017
Hi Nick
Yes you can have separate VLANs for different SSIDs. Let me know if you have any further questions on this
Thanks
Raghu
NickHW
Jun 06, 2017Aspirant
This would be standalone mode.
I have a pfsense firewall / router, connected to a GS728TP. I want to attach an access point to the switch that can tag different VAPs to different VLANs from the switch to partition the traffic.
So the AP will be on a switch port with tagged ingress and egress. Each VAP would have separate SSID and communicate via a separate VLAN.
- RaghuHRJun 06, 2017NETGEAR Expert
Hi Nick
Thanks
Raghu
